taking on water
  • taking on water
    i have an older argo 6x6 vangard and am wondering where it might be taking on water i have checked the hull like 5 times and believe it to be good. Is it leaking around the bearings and how do you seal that up
    If the bearing is bad it could be leaking through the bearing. Replace bearing. There is also a cork seal between the bearing and body. Probably not on all years so it may not be cork? But you can replace that with caulk rope to seal it.
    A safe way to check where its coming from is to fill the inside up with water and see where it comes out. If you can do it on a trailer then its even easier to check where. Another way is remove the floor pans and carefully drive it in water. Just dont get your feet caught in anything. Then you can see where its coming from. But that way is dangerous. And harder examine.
