I have a Bigfoot that tops around 18mph. My bigfoot has an 18hp engine. I've noted that newer 6x6's have the 23hp engine, but still claim to max around 20mph. Although it will have more torque, the extra HP should make it faster (in my opinion). What is preventing these machines from going over 35mph? I've noted that older machines are faster. Any ideas?
Million $ Question: How can I make by Argo faster?
to make your top speed faster ,you need to take out the idler shaft and put smaller sprokets on the input OR larger sproket on the output, do you run double fifty chain or something else ??? ,do NOT change the sprokets on the axles or you will have to do ALL of them to match, the only options you have to change sproket ratios is either the trani sprokets or the idler sprokets, i did the idlers on one of my 6x6s and it now does almost 50 clicks and that is nearly insanely fast, ive had many of the tranis apart from the early eighties to the late ninties and never seen a gearing difference but the tooth sizes were changed several times by the engineers trying to adress a weakness in the trani of all argos ,i believe that is why they have re-engineered the entire trani in the new ones , if you need more specific help in this let me know, i can calculate the sproket sizes for you, each tooth on a sproket decreases or increases the overall ground speed by a specific percentage ,but you need to watch chain clearences as wellHe who has not cruised the back country in a 6x6 , has not lived life to it's fullest
The later argos, pre avenger and frontier, at least back to the mid '90's, had three different ratio trans available. There is a gear set that will swap out. I should say at least two, the MU and GU, code stamped on the top of the trans case. There is an H, I guess that's what the early vanguards that were so fast had. G lowest, M higher, H highest geared/lowest ratio. I think the M is most common, but my distributor ordered all Responses with the G to make sure they had enough power.
Making the bigfoot faster, he could spend $75 on valve springs, retainers, and pushrods and run 4500 rpm safely with the govenor bypassed.To Invent, you need a good imagination and a pile of junk. (Thomas Edison)
Thank to all for your responses. Trebmaster, that makes sense now. I would love to get into the tranny and tinker with the gears, but this is something I've never done and probably shouldn't. Knowing my abilities, I'll probably put something backwards or end up with some extra parts. As you can see, I'm not very advanced in the world of mechanics. I can do some tweaking, maintenance, and light troubleshooting only. Too bad I live so far South, I would have loved to team up with any of you guys and paid to have done this together. It looks like I'll have to settle for my lightning fast 18mph Argo. I can almost run next to it.
Hey RobinHood, thanks for the post regarding making my Argo faster. I've read your response a few times and I'm now realizing that you are referring to the sprockets that are external to the transmission. Are the idler sprockets the one's that have the double-chain coming out by both sides of the transmission? Did you change the sprockets on the top of the chain (coming from the transmission) or the bottom of the chain (connecting to the shaft) ? I'm very interested in this as this is something that I may be able to handle. If you happen to have a picture and identify the input and output sprockets, it would be helpful. Also, where could I buy the suggested sprockets? Thanks.
Miami, if your bigfoot has all double chain throughout you should see something like 19 and 24 tooth sprockets, I guess on a bigfoot it would be 2nd and third axles with the 19 tooth. If you have some single chain you may not use them. I think that's what Robinhood is talking about. If you used a 19 on the countershaft it would be a big gearing difference. However unless you do all flat terrain you might not like it.
If your trans says MU on the top, and you have 25" tires, I'd make sure the clutches are working right(the belt goes all the way to the outside of the engine clutch) and do engine/govenor mods. That should be plenty fast, unless you are on very flat and smooth land all the time.To Invent, you need a good imagination and a pile of junk. (Thomas Edison)
You can disconnect it and be ok. Long term it's better to take it out internally but no big deal. More important is replacing valve spring retainers, shimming or replacing the springs, and changing pushrods. The valves will float otherwise.To Invent, you need a good imagination and a pile of junk. (Thomas Edison)
