Well, I finally got this little project started
I have to say here that I'm NOT SURE if this will work with ALL Conquests. I have noted that some older Conquests have different Bearing Extensions. Mine has the ones that require both the inner and outer bearing retainer when mounting Bearings in the bearing extensions. Some Conquests bearing extensions have the inner bearing retainer built into the bearing extensions. It may work, it may not. To find out what you have, look at your machines front/rear bearing extension assemblies. If you only see one gasket behind your outer bearing retainers, you have built in INNER bearing retainers. If you see 2 gaskets with a plate between, you have the same assemblies as mine.
PART-1 (Front/Rear Axle Conversion)
PART-2 (Mid Axle Conversion)
