Hello, I am wanting to purchase an outboard for my argo bigfoot. Now I know they have to be long shaft but what I am wondering is would I get much of a power increase with the 9.9hp compared to a 7.5?
outboard 7.5 vs 9.9
RD is right they are just like a barg in the water, i have tried 2hp-9.9hp on an 8x8 and the 7.5 was the best one and the weight/size between the 7.5 and 9.9 is massive, i would not even attempt to mount a 9.9 on a 6x6 lol'99 Conquest 104hp turbocharged intercooled EFI Chevy Sprint conversion
"Argo 8x8's only" type of guy
"old school Argo expert
What you will see is a weight difference. The 7.5 will be just as effective as the 9.9. I run the 9.9 on my Avenger and even with the long shaft when you try to really grab some gusto the long shaft will still have cavitation. This is due mainly to the wheels disturbing the water prior to its arrival at the prop. I think!! In my opinion i think the 9.9 will be a bit heavy for the bigfoot. The big thing about the outboard is...you ain't going to set any water speed records with it. My 9.9 is a 4 stroke Mariner motor, so i am assuming this is the type you are speaking of. It will propel you at a pretty good pace but it will take a little time to get up to speed.
I think the four stroke is around 90 lbs. I am not exactly sure but you can check the outboard sites for weights on each unit. The 9.9 is easier mounted by 2 people.Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
