Hi There
I have an 07 avenger EFI with about 80 hours on it. I recently did the regular maintenance to it and notcied the one of the front axles has a very small(very small) wiggle to it. Now I assume this is a bearing issue, I greased the outer one as per usual and it seemed to help a little bit. I have yet to grease the inner one as I have been warned about "over greasing" these, should I try this? How serious is this? Not having done this how difficult are they to change and how do you determine which bearing is the cause, does only the outer one cause this wiggle?
Thanks in advance.
Mike
Thanks in advance.
Mike
Grease usually starts ooozing out around the bearing retainers long before I see any coming out the seals.
