Well after a year of it sitting and me deciding I'll pull the motor and put something that actually runs in it's place I thought I would have one last look, deciding there is no fuel I thought the pump had gone, took it apart and there was nothing wrong with it, it's pumped fuel after I put it back together and so i stripped and cleaned the carm for hte 10th time, all passages are clear so why the hell is there no fuel. Well the old main jet and holder had broken off meaning I needed a new float bowl, and main jet assembly, looking at the old carb I noted that it had a fixed jet and the bolt that held the float bowl had no provision for jetting as this was located on the side. The extraction of the old jet had holes drilled in the side to allow fuel up to the main jet, the new one did not! after all this time, 2 small holes drilled in the float bowl bolt and it ran, and has not stopped since. Now to tackle the wheel bearing!
Early Argo is Alive!
