does any on know how or if you can tighten the front drive chains on an argo? thanx for all the help you give have given me along the way!
how do you tighten the front chains on an argo?
my argo has 1058 miles on it since i got it in spring and ive been noticing the front chains slowly getting slacker.
but i did just figure it would come to a point and just remove a link ... now you guys are talking remove the entire chain???
dont think i will like to replace these every 6 months... that sounds wrong
and it isnt fun to replace chains with tracks on ,;((
Don't cheap out when you buy chain. If you do then be prepared to buy twice as much.Originally posted by bart oosterbaan View Posti see what you mean , but i still cant see myslef replacing these chains every 1200 miles,,,
there has to be a way to weld somthing in place with some teflon on it that take up some slack
wonder what these chains cost?
Double strand 50 is $15.00 / foot where I am.
ive seen those ring tensioners before, they do well on steady constant speed uses, but where the application bounces and snap loads they just fall out and go wrap around the sprokets, not quite the app for those ringsHe who has not cruised the back country in a 6x6 , has not lived life to it's fullest
[ QUOTE ] ' they do well on steady constant speed uses, but where the application bounces and snap loads they just fall out and go wrap around the sprokets, not quite the app for those rings '
Matt Oxender used the roll ring ,chain tensioners on his Mudd-Ox for about two years,and ran his machine VERY HARD for testing purposes to see if any thing would break. Because the roll ring had proven reliable during this period of time, Matt released the first Mudd-Ox machines for sale to the public. Matt later decided to go to another chain tensioner design. Matt never had a problem with the roll ring chain tensioners, because he always kept his lower tub clean. But, for the people who failed to keep their lower tub free of small limbs and branches, they had a problem with the roll ring chain tensioners. If a large enough branch or limb came in contact with the roll ring, it would then get dislodged. Also ,when there was enough stretch in the chain, the roll ring would expand even farther, and this would cause the roll ring to push the chain out against the lower tub, and rub against it. The roll rings also needed to be replaced after about 80 hours of use. Matt told me that the cost of the roll rings was about $91 now? These are the reasons that Matt no longer uses the roll rings.
This is a torsion spring, chain tensioner that I,m going to install on my Max IV and Hustler. I talked to Matt Oxender on the phone , and he really likes this chain tensioner too. When I received one of these chain tensioners in the mail from Monstercraftman, my initial thought was WOW! I was inpressed! The spring tension can be set by two different tension tabs that are on the adjuster. The torsion spring on this tensioner is very strong too! Once the initial chain stretch is finished , the chain tension is then automatically adjusted.
[ QUOTE ] ' Can someone please explain to me why ARGO doesn't use something like that ? '
Paquette
One reason that I could see is having the space to fit this style of chain tensioner in. But,, as I have posted already,, these chain tensioners are outstanding and very simple to mount!Last edited by mudbug3; 10-01-2010, 11:04 PM.
