Hello Guys,
I am currently working on changing my Avenger axles bearings to the new HDI bearings and while looking inside there I noticed that my whole idler shaft bearing will slowly spin in the flange assembly. I assumed that the bolts holding the two flanges were loose, but they are not. Then I thought the bearing maybe was on the way out, so I took the idler shaft out, and the bearings appear to be okay. So if the bearings are good, and the housing is tight, any idea what may be causing this?
One idea is that I may have greased it too much, causing the flange to push out, allowing just enough play to make the (supposed to be) solid part of the bearing turn?????
Any ideas?
Derek
Any ideas?
Derek
