I want to track trhe front two tires on my 8 wheel argo how many links do i need??????
Argo 1/2 tracks
A few questions, if you don't mindOriginally posted by 28560HUNTING View Postno not much slack maybe too tight had to use large channel locks to squeeze segiments together approx 2inches
Were the track segments new?
Where did they break?
When you put the tracks on, were your tires inflated or flat? (I install my tracks with the tires flat, then air up the tires to get the track tension that I want)
Did you measure your track tension in some way, after you put them on? (Trying to get a feel for weather they were too tight or not
The reason I'm asking is that I have 2 sets of tracks, and have never "Broke" a segment
. I've worn them out, and munched up some guides, but never actually broke any.
There are really not many ways to put tracks on wrong, so you should be able to get this straightened out pretty quick.
How much pressure are you putting in your tires?
I run about 3psi without tracks and up to , but preferably under, 5psi with tracks.
OK, I have had a few of the "Pin Lugs" break off segments, usually when the segment is pretty worn out and it has always been the ones on the outside edge of the segments.
I try to replace segments when the "Pin Lugs" are worn about 2/3 of the way through, or so.
Another question:
Are you running 22" Runamuck Tires?
Well, A bad day hunting is still better than a good day at work
Not sure what to say about the tracks
Are they OLD, maybe been sitting out in the sun for a period of time (UV damaged)? Not that I've ever heard of UV damage to tracks, but I guess it might be possible.
Can you get us some detailed, close-up pics?
