cable ties.jpgHi
I was struggling to join the front chains on my argo. I did not have the special argo tool (modified vice grip pliers) and I came up with this solution. Forgive me if it has already been put forward(I searched but could not find anything on this).
Its simple; get hold of 2 cable ties (you might call them ratchet ties) Thread them around the two end rollers of the chain you wish to join with the con link and gradually pull them tight until the holes are the right distance to get the con link in. Then partially thread the con link in, add the two middle links and tap it through.
I find temporarily placing another con link partially into the chain in the opposite direction holds everything in alignment allowing easier fitting.
Have attached pic showing two cable ties hoding chain ends together.
Cyclone
Cyclone
