The sprockets that I have on the output shafts of the trans are worn. I have single 40 chain on a 197? 6x6 argo. It has 15 tooth sprockets that are welded to the brake rotor. Argo dealer says he cannot get replacement parts from Argo but is going to keep looking elsewhere. I am thinking that I could remove the old sprocket and replace it with a weld-on sprocket and hug assy. Problem is that I cannot get a 15 tooth sprocket in a hub for 1" shaft. I can get a 16 tooth on a 1" shaft, but the question is, will my machine be too fast? I have never drove the machine, so I am new, I got the argo minus an engine. I have a 440 rotax already mounted. The trans is stamped 0184.
thanks
thanks
