I have a 2010 Frontier 650 23hp Briggs and Stratton. Have starting question. When engine sits for 4 or 5 days, when I go to start it, it seems to turn over alot before it starts. I pulled the choke out all the way, give it 1/4 throttle, turns over for 20 or 30 seconds, won't fire. If I wait 30 seconds, to cool starter, try again and it usually fires up.
Has anyone got a different firing procedure when cold? Once it has started, it starts again easily all day. Just wondering if fuel runs back to tank when sitting? Tank is lower than fuel pump. On my riding lawn mower, fuel tank is higher than fuel pump and it starts right away. I had a 20hp Kawasaki in my last Argo, it had an electric fuel pump and would start up without a problem. Just wondering if maybe I could put a big primer bulb on fuel line and when it was cold, primed it a fuel times to pump fuel to the pump - would it start easier or would it blow a diaphragm or something else. I realize that the vacuum from the motor sucks fuel to the pump.
