Just thought I'd share this. I recently did a little research on headlight bulbs. Argo uses an 800 series bulb 37.5 w, forgot the number but it uses the same connector as an 890 50w bulb. I swapped mine out the other day and they are awesome. The wire should be more than good for the minimal increase in amp draw. Not sure if argo was just trying to be easy on the charging system or what? I have an alternator so I'm not worried. This should worl for most argos mine is a 2005 avenger. Let me know what you guys think.
Argo headlight upgrade
I recently installed a pair of Vison X Solo Solstice LED driving lights on an 08 Avenger 750 EFI, great solution for lighting. The Vision X people sent me some extra lenses to test and I decided the Medium Beam (formerly the SPOT) was the best. The factory oval headlights are OK as floods but lack any long distance functionality. The Vision X is an LED matrix that draws only .75 amps each but produces about the same light as a 70 - 100 watt halogen- tremendous amount of light for a slow moving Argo. They are very small, can be ganged together on all four sides, and can be mounted on a handle for a search light. The case is cast aluminum- I think the light would withstand just about any impact. They easily mounted inside the brush guard. The only ouch was the price...tmwoffroad.com had them for $99 each and free shipping. Will be putting up a video soon. -- Roy
Originally posted by moonbuggy View PostI recently installed a pair of Vison X Solo Solstice LED driving lights on an 08 Avenger 750 EFI, great solution for lighting. The Vision X people sent me some extra lenses to test and I decided the Medium Beam (formerly the SPOT) was the best. The factory oval headlights are OK as floods but lack any long distance functionality. The Vision X is an LED matrix that draws only .75 amps each but produces about the same light as a 70 - 100 watt halogen- tremendous amount of light for a slow moving Argo. They are very small, can be ganged together on all four sides, and can be mounted on a handle for a search light. The case is cast aluminum- I think the light would withstand just about any impact. They easily mounted inside the brush guard. The only ouch was the price...tmwoffroad.com had them for $99 each and free shipping. Will be putting up a video soon. -- Roy
here are the LED bulbs I installed in my Max IV
LED Bulbs, LED Light Bulbs, LED Light Bulb & Car Parts for Sale - DealExtreme
2008 MAX-IV 500T 30hp Bandolero
