Brand new to the AATV world...bought an old argo, went and drove it, didn't know what I was looking for or at...appeared good all around and took it home...
pushed it out of the trailer into the garage. Dad came by to look at it, I fired it up and let it warm up, revved it up to show him that the clutches shift out and whop! the driven clutch threw the brass bushing out of it!!! 1 pc on the bottom of the floor and the other stayed around the shaft under the drive belt.
From the break it looks like had been like that for some time, just happened to come apart then.
I guess that's what I get for buying a 30 year old machine!!!!
Now the question: Is the bushing replaceable or should I just put a new clutch in it?
It's a 399cc kohler and I assume its a comet clutch, but not sure...do I need to pull the motor out to get the drive clutch off? Looks close, do these come off like a snowmobile clutch and puller/rod?
As well, one of the balloon tires does not hold air, does anybody have any of these around? LH side...
Thanks for any help!
doug
From the break it looks like had been like that for some time, just happened to come apart then.I guess that's what I get for buying a 30 year old machine!!!!
doug
. Might be that you are overfull, or might be contaminated with something. Safest bet is to drain the trans fluid and put new stuff in. 80W-90 Hypoid Gear Oil with a little limited slip diff additive is good.
