I have a question for the Conquest experts. I just bought my first Argo yesterday, a used 2001 Conquest 8x8. I downloaded all the manuals I could find and did a quick read. The machine appears to be in very good condition overall. A few of the drive chains appeared loose. I pulled up on the tensioners as the manual said. The pawl clicked and took up the slack. But the two chains driving the front wheels are shorter than the others and appear way too loose. I dont see any tensioners on these two chains. One is almost hidden by the battery. I can't find a reference in the manual. What am I missing? I see McMaster Carr has a couple of types of chain tensioners that might fit if there is enough clearance. How do i solve this problem? Thanks
Conquest front chain tension adjustment?
The only proper way to deal with loose front chains is to change them. Just did the front chains on my conquest, took an hour or so and about $100 worth of chain. I purchased the front chains direct from argo because I was in a hurry. You can probably do it cheaper if you buy a roll of chain and cut it to length. Good luck.
I'm not a fan of Halflinks either
Halflinks are weak links
Adding a halflink to a stretched chain will cause extra wear on sprockets, and can be sticky on the sprocket due to the difference in pitch with the worn chain.
Really, it's not THAT bad, but I still lean away from using them, unless I'm in a bind.
