hi all i have a question about my right side idler shaft. I took this out today because the outer bearing (the one closest to the outside of the body) was bad the end of the shaft is slightly mushroomed and what was left of the bearing seemed to be loose on the shaft is the bearing supposed to be loose on the shaft (note the bearing is the set screw type ) or is it supposed to slide tight on the shaft i just dont know and i dont want to get a new bearing to find out i need a new idler shaft i would rather get them both at the same time if it is needed thanks agian for all your help
81 idler shaft assembaly
