We have dog fish here and ours look similar but different coloring. Must be just a different variety. They do have that long fin. They are also called bowfin.
argo pulls to the right
Originally posted by LarryW View PostHey plott hound,
What kind of fish is that?
Edit: see Burbot
Snakehead Information - Fish and Fishing Frequently Asked Questions (FAQ) - WDNR
Boys these are called ling cod or burbot.they are called the poor mans lobster.all the meat off the tail is removed,cubed,boiled and dipped in garlic butter.tastes just like lobster.we catch lots of these in canada(saskatchewan)not much to do here in the winter after hunting season closes.ice fish,drink and you get the drift i`m sure.
Originally posted by plott hound View Postdog fish,ling.freshwater cod.they are real fugly but super tasty.
Cube it, boil in "Mtn Dew" (Yes, the soda pop)
Dip in garlic butter, and you're stylin'
One thing about the machine pulling to the right, might just be becouse you sit on the right side, try shuffling over if traveling alone. If you get the machine to track straight with just you in it, it will track to the left when you have a passenger.
Tight lines
If and only if you think no mechanical resolutions are needed, I would let air out of all tires on the oppsite side of the pull until it stops pulling. If you are running flats on the left, and still pulling to the right, you've got mechanical issues.
I used to ride a wheelie on my quads to determine if the rear tire pressures were correct. Sounds silly but this trick helped with fatague on long quad trips.
i took all the tires off this morning and measured circumference of each.variation was about 1.5 inches,68.5" to 70".aired them up or down to make them all 69.5" in diameter now my psi varies from 4 to 6.should i put the higher psi tires in the middle or does it matter withoot the tracks on machine?without the tracks it pulls to the left.
cheers.
Hi, I may be late on the answer but check your brakes. I have the same problem with my avenger but when I put all 8 wheels up an free and put the argo in gear there is only one side going. I just touch the brake on one side a bit and corrects it. My problem are my band brakes I thinkJack
hi' i have an 87 and mine was doing the same. i even adjusted the brakes and still was doing it. found out the steering rods were sticking. took some wd40 and sprayed it on the rods and it seem to help, but i know the newer ones have different controls now from the 80's style hopefully it's fixed
Cube it, boil in "Mtn Dew" (Yes, the soda pop) first ive heard of that one rd. tried the burbot thing and am not much for the boiled idea. deep fried this fish is just as good as any other. ahh still have a thing for the ol marble eye! gonna have to try that suggestion though. dare i ask where in the world you got the idea to boil in mountain dew.. sorry for getting off topic just had to comment have a gooder
