I have a argo vangaurd 6x6 with 22x10x8 and 20x10x8.I can get a set of 24x10x8 will they fit my argo.any help would be great
24" Tires on Argo Vanguard
I have 24" Frontier Tires on my Conquest, but it's a VERY tight fit.
In theory the tires should fit, but there are a couple issues. 1) Your axles can be slightly more or less than 24" C-C (I know mine are off just a bit)
2) The tires might not be perfectly round (Mine are NOT) 3) Juggling the tires around on the machine to get the high points of some tires to run into the low spots of the next tires can take hours. 4) Different tires can inflate to different sizes with the same pressure in them (I have found as much as 1.75" differance in circumferances at the same pressures)
