well i put a new motor in my 1988 i thought i got the new motor in the right spot but i must have screwed up when i start the engine the primary clutch engages just a little bit but enough to contact the belt and turn it i cant shift the tranny unless it is shut off is there anything i can try doing before i cut the motor mount and move it ahead.
the factory belt is 52" if i had one that was a bit longer it would probably work but i cant find one longer would a narrower belt help or would that cause a power problem
PLEASE HELP
PLEASE HELP
