I'll do some tooth counting and figuring tomorrow. Maybe a combination of 2-4 fewer teeth, and some higher rev mods to the twin will get just what I want.
Changing speed with sprockets?? Possible??
Originally posted by Stonewall View PostI'll do some tooth counting and figuring tomorrow. Maybe a combination of 2-4 fewer teeth, and some higher rev mods to the twin will get just what I want.He who has not cruised the back country in a 6x6 , has not lived life to it's fullest
29 mph sounds great, I just want to make it a little bit more practical for running around fields checking stuff, and more fun of course.
Jersey, I'd like to know more about the higher rev mods that you have done.1983 Hustler 945-HK 627cc Vanguard
2010 Chevy Silverado 1500
1974 Honda ATC 70
1986 Honda ATC 250ES Big Red
There is no Z in Diesel!!
Depending on the engine you are either moving springs or adjusting screws or bending the governor tangs (Briggs vanguard). you should also have a good tach. I have a good induction meter. Another solution is to remove the mechanical Governor and add a small engine rev limiter (they are pricy). Briggs and Kohler v twins have a restricted stock exhaust and can only over rev in neutral or screaming down a hill. There are plenty of engine manuals on line or for sale that describe the adjustment. There have been posts here describing the adjustment for quite a few engines already. I just did a search for governors and there was about 100 posts. lifold did a partial governor bypass that works well. I think he has photos of the mod.Acta non verba
eh thanks alot there Jersey, i'll do some checking. i've always thought that they were governed too low, if you look up the power band of a 18 hp briggs you'll see the powerband is from 2200 rpm to about 4200 rpm , they cut off 65% of the potential horse power by governing it to max out at 2800 to 3200, you mentioned that it needs new springs ,do you know what rpm the valves start floating ?He who has not cruised the back country in a 6x6 , has not lived life to it's fullest
Robinhood, I counted teeth on my sprockets this morning, and you were right, the driven do have 30 teeth. The t-20 sprockets have 15.
Jersey, I am using a Kohler CH25 on my machine, and will not be using the stock exhaust, just straight pipes.(with rain caps) Everything else will be stock. What tach do you recommend? Is the Sunpro tach that I can get at Autozone good enough?
1974 Honda ATC 70
ok, drop 4 teeth and put on the larger tires and you should get 29.58 mph ( presuming your motor will maintain its original maximum rpm)
figure out how to adjust your governor 500 rpm more and you'll have aprox. 33.31 mph, (this also presumes your back will be able to take those speeds) being 16 well you can probably take it LOL (not these old bones)He who has not cruised the back country in a 6x6 , has not lived life to it's fullest
Originally posted by Robinhood02 View Post(this also presumes your back will be able to take those speeds) being 16 well you can probably take it LOL (not these old bones)1983 Hustler 945-HK 627cc Vanguard
1974 Honda ATC 70
You want an inductive tach like an Equus 6068 It gets the signal off the plug wire. Briggs start to float their valves around 4500 rpm depending on the age of the engine. Some rev kits will have springs some will have shims for the existing springs. They will also have heavier alum push rods or some people replace the aluminum push rod with the steel push rodActa non verba
The tach Jersey mentioned is a pretty good tach i have one on the Crush.
Equus+6068 - JEGS High PerformanceLife should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
Back out of the ashes for a another look. I've been trying to research this topic in the hopes 30-35ish mph was possible with the Argos and still have Lo range for the nasty stuff. We run a lot of smooth gravel roads and such and could honestly benefit from the speed increase to cover the smooth ground.
But I sure wanted to retain low end for the slow tedious terrain. Will low range accommodate this? I'm not opposed to engine mods what so ever.
Thanks for the info in this thread
Originally posted by TURNEROFFROAD View PostBack out of the ashes for a another look. I've been trying to research this topic in the hopes 30-35ish mph was possible with the Argos and still have Lo range for the nasty stuff. We run a lot of smooth gravel roads and such and could honestly benefit from the speed increase to cover the smooth ground.
