removing belt argo avenger
  • removing belt argo avenger
    Does anybody knows an easy way to remove the drive belt on the argo avenger 2005 kohler aegis 26 hp engine?
    Jack
    Put the trans in N
    Pull the belt to the side a bit (Away from the trans)
    Roll the Secondary clutch backwards
    Belt should come right off
      Thank you, I'm also having a lot of problem removing the transmission drain plug. It is so tight that I'm afraid of striiping or breaking. Can I just pump out the oil or it is necessary to remove to drain plug.
      Sorry, I'm not a mechanic but try to do maintenance. With experience I'll learn
      Jack
      Jack
        Sounds like someone put "Locktight" or another similar product on it.
        First make sure you have the proper size wrench/socket (Box end of the wrench or Socket preferably), then try it again. If you just can not get it, try (CAREFULLY) heating it with something like a BENZO Torch, or even a Micro Torch. Try it again after it's heated up.
        Hopefully that works for you.
        NOTE, Drain plugs don't need to be screeming tight.
          Thank you RD,
          I got the belt out and with a lot of strenght I got the transy drain plug out. I put SAE80W90 in it. I hope it's ok. I also got the engine motor oil pumped out. Thank's to this site. I can learn a lot and not having to bring the argo to the dealer.
          Jack
            80W90 is fine. You might want to add a few ounces of "Limited Slip Differential" Additive to it. Not required, but some guys think it helps.
