On a 1985 Argo 8x8 should I be able to get the cross mount bolts out to remove the trans without removing the clutch and drive sprockets? I cant seem to get the clutch off to remove the drive sprocket and brake rotor which are blocking the bolt from coming out. Am I missing something or will I have to remove the bolt heads with a sawzall?
Argo Transmission Removal
its very close but yes you do in fact have to remove the discs, you would have thought some engineer could have moved the bolt lacations 1/4 inch to save the hassle but i guess that would have been too easy lol'99 Conquest 104hp turbocharged intercooled EFI Chevy Sprint conversion
"Argo 8x8's only" type of guy
"old school Argo expert"
You might look into removing the engine & transmission out of the Argo while they are still mounted on their sub frame if you have a good enough hoist available. That way you can get at the clutch and brake discs easier for your efforts to get them off rather than getting frustrated with bending over your rig.
Try some heat and penetrating oil on that stubborn clutch...
Originally posted by AlaskaGrizzly View PostYou might look into removing the engine & transmission out of the Argo while they are still mounted on their sub frame if you have a good enough hoist available. That way you can get at the clutch and brake discs easier for your efforts to get them off rather than getting frustrated with bending over your rig.
This ^ is actually not very hard to do, pull 3 bolts and disconect some wires. Don't need much in the way of a hoist, a couple guys can walk away with the engine and trans assembly without to much trouble. Might consider installing an alternator while you have the engine out.
NOTE: If you are just pulling the trans, make sure you lift the trans high enough so that when you pull the brake rotors, they clear the sprockets on the idler shafts. There are several pullers that will work good to pull the Brake rotors, but pulling the clutch can be a pain sometimes if it was assembled in the past without some type of anti-sieze.
Well, I got it out. I backed the bolts against the rotors and cut the heads off with a sawzall. I tried heat and pb blasater for several days. I dont have it apart yet but opened the cover enough to drain the oil out. Pretty sure it had more water than oil.
