I have had a spongy brake on the left side for a couple of months. It is okay (spongy but works) when it is warm out (above freezing), but does not work at all when it is below freezing. Just now getting around to fixing it.
Here is the thing: It is not air in the lines; they have been bled over and over again. I rebuilt the master cylinder a year ago and I assumed I have damaged one of the seals in the install so I replaced the entire master cylinder this week. I was sure this would fix the problem.
Has anyone ever had to replace the seals in the brake cylinders? It is the only thing left to change in the system, so I am assuming it is the problem. Is it a big job?
Derek
Edit: Sorry, should say "Hydraulic Brake Spongy). ???
Derek
