I'll vouch for the performance of the adair tracks. Vader was unstoppable where we rode a couple weeks ago. I took video but haven't figured out how to get it from my player to a movie maker program to edit it. Try again tonight. Happy Trails
How much is a 66 track kit worth?
Stock 24" tires on my machine, no wheel spacers. They were shipped with extra segments to add on, just in case, but came the right length. It's pretty easy to fit them to your machine. . ( you do need to cut the chain to your required length, anyone need tips PM me) . I would call Adair and just tell them what your running. A.J. I have to say, you need to see these tracks in person. The motor loads less and the machine turns and runs easier on almost all terrain than tires. AND I CAN GO THROUGH ALMOST ANYTHING. I lost 1 mph in top speed. They are worthy. I haven't seen any good pics of them up close that shows the stout construction up close. I guess I'll have to post some..... Hi Mike....Last edited by vader8x8; 06-03-2011, 10:30 PM.
Originally posted by Castro View Postdo the adairs run on the same 22 inch that the polys run on? I think i am going adair and stick with my 13 inchers for snow. I am just starting to see that I got a smoking deal on my tracks and tires. Do you require spaceds for the adair tracks?
I absolutely agree with Vader, these tracks are unstoppable, the machine rides better, has more ground clearance, turns easier, they will go through the worst swamp and marsh and will out perform any other track or tire combination I have seen
Adair Argo Tracks
Fender clearance is better on newer machines like Vaders 8x8 Frontier....largest tire argo ever used with track kits on older generation machines like the BigFoot 6x6 was a 22x10x8 runamuk...that would be an ideal size to use on a big lug track, but the tire that they have listed with the kit is just slightly larger at 22.5x10x8 and is built by Carlies (trying to maximize ground clearance)....if you already have a set of 22"'s or even older 21"'s you probably wouldnt want the added expense of slightly taller tires and the standard 6x6 Vangard ll kit (which came stock with 22"'s) would work
hope this helps
