I am still looking for my first Argo on the used bulletin boards up here in Ontario Canada and there is an interesting Bigfoot ...
ATVs seem to be rated by the manufacturer at about 25 degrees safe hill handling and the only reference I found for an Argo said 30 degrees.
I need to get back to small trout lakes in the steep and rocky hills. Sometimes those trails hit around 40 degrees I would say. Quads certainly get jittery even just crawling up or down. If you rolll it is all the way to the bottom. Trails often are straight down.
Will a BigFoot do better creeping up and going down those hills?
Is braking downhill an issue in a 2002 BigFoot?
I want safety, payload ability and do not need speed!
Any advice or observations would be appreciated!
Next I need to learn to drive an Argo ..
I sent BearFish a private message and I suggested the exact same thing as you did..
