hey i am wondering where the normal mounting location for the regulator-rectifier for the engine charging system is on a hdi with a lh775. ill explain why, i bought a 2011 750 hdi with alternator kit installed and have had no problems with it, but in case of a alternator failure or blown belt in the middle of no where i would like to have a back up charging system. It appears that either the dealer removed the regulator-rectifier when they installed the alternator or the dealer ordered the argo with the alternator and it did not come with one installed, in any case i would like to be able to unplug the alternator and plug in the regulator-rectifier (or throw a switch) in case of a alt failure to be able to finish a hunt or make it back to camp/truck. i have found the wiring/plug for the reg/rec but cant see where the unit itself mounts im thinking on the rad support bracket but could be wrong if someone could take a look for me (mabye snap a picture of location and orientation) that would be great or let me know if you see any problems with my plan.
thank you dromas
thank you dromas
