just finished drive train refurb so now looking at the tranny. there are times that i have trouble shifting the gears from nuetral to either low or high. it will grind the gears. i have to pull the choke out to reduce the rpm to shift smoothly. doesn't grind all the time but tends to do it after the engine warms up. i set the idle low enough to get smooth function when first starting but later starts to act up and i have to adjust idle again or choke it. if i set the idle any lower it won't run unless given throttle until the engine heats up. this is not an option either so looking for some feed back from others.
thanks trevor
thanks trevor
