ok foul for today I am doing a frame up build. got motor on floor clean it up change oil and rad fluild mount back in frame pack put disk cooler duct in trans back in hey i better try the starter .guess what it dont work.if you have ever had to remove one they are not fun take it down clean it up lathe check it put it back in.works great not going to be promblem with alt that is new. But if this had been in tub and had hood on it had been a bear .but sitting on saw horses not bad also while i had it this far mounted switchable bilage up in front left corner you guys running the hose right or left side.
