Good day everyone,
I have a conquest with the kawi engine in it. I have found recently that the stock charging system just does not seem to cut it on this machine. I just wanted some input before i make the changes i have planned.
I have removed the factory sized battery, and was planning on relocating a larger battery to the rear of the machine somewhere. I would like to have a winch on both ends of the machine, so i am going to end up running some wiring anyway. I will have 2 winches, stock headlights, brake fan and occasionally a cell phone booster drawing on the charging system.
Will one large car size battery be enough to power these accesories? I rarely use the winches, only in a recovery situation.
Will the factory charging system be able to replenish the battery in everyday situations? Will i constantly be killing the larger battery?
Does anyone know what the charging system in the FD620 is rated for? What does the brake fan pull for amperage?
Will i be able to mount an extra set of headlights on this machine with the bigger battery and still maintain battery power? Should i add 2 big batteries?
Where does everyone else locate the bigger batteries? Has anyone done this before?
Sorry for all of the questions, i am just trying to make sure that i make the right decision. I really dont want to spend 500 bucks on an alternator kit if i dont have to. Thanks in advance for your help.
