I was looking at buying an argo 8 wheel mid 80's , but it has a cracked bottom pan can it be repaired or does it have to be replaced ?[/B][/B]
Cracked Pan
I'd drain the fuel out of the fuel tank, then start it up and run it till it quits. Then drain the oil from the engine. Roll it over so the bottom is up. Make sure you put some blocks under it so it doesn't damage the steering.
You can now weld on it all you want and there is nothing in the way. Just make sure the fuel tank is dry.
SlimSlimpickin
This unit was sitting for 11yrs so it might not hurt to take it apart to the frame and do a complete rebuild on it.
