i live in oshawa ontario i posted some pics of the argo im buying can any one tell me a little about it buy looking at it pics are in here some were i dont no were
getting old 8x8 saturday
Last edited by Mike; 12-02-2011, 06:28 PM. Reason: moved post from introduction thread to its own thread in the appropriate forumTags: None
Hey bear found pics yea late 70,s early eighty,s,with the Tecumseh single banger,mechanical brakes,they were a decent stick wouldn't break any speed records but they lasted well,should be a ton of parts out there lots were sold back then,too bad I did a huge clean out awhile ago and tossed out boxes of parts that would have fit that,but if anything turns up on my next purge I will let you know.Cheers N.C.TOriginally posted by bearkat View Post
thanks started takeing out axels to change bearings but they are hard to get out i put a big puller on after pounding out the axel from the inner bearing on frame then pulled it out and pulled all the rest off also loosend those collars now using emery cloth to clean axel and inside of sprocket collar will post pics as im going
Project for sure put up pics of your progress and get a extra tub of hand cleaner.Originally posted by bearkat View Postthanks started takeing out axels to change bearings but they are hard to get out i put a big puller on after pounding out the axel from the inner bearing on frame then pulled it out and pulled all the rest off also loosend those collars now using emery cloth to clean axel and inside of sprocket collar will post pics as im going
if it is the sheer pin style, just knock the pins out, hose it down with your choice of PB blaster, WD 40, liquid wrench or what ever in any combination of and drive it around the yard. It will free itself eventualy from the sprockets... just make sure that you dont get too far from home, kind of embarasing if you have to walk back
ATV = Alaska Terain Vehicle
Good one Spookum nice trick.LOLOriginally posted by spookum View Postif it is the sheer pin style, just knock the pins out, hose it down with your choice of PB blaster, WD 40, liquid wrench or what ever in any combination of and drive it around the yard. It will free itself eventualy from the sprockets... just make sure that you dont get too far from home, kind of embarasing if you have to walk back
