LCD Instrument cluster
  • LCD Instrument cluster
    Just wondering if it is normal that the temperature level always stay at low ( 1 Bar )
    even if I ride in warm or cold weather, low speed or high, on road or rough terrain.
    My Argo is HDI 750 2011 with a heater.
    When I look in the instruction manual they says 1 bar = 131 F. which is well under the temperature where the 205 F thermostat open.
    No it's not normal to sit at (1 bar). On average it should sit at (3 bars) during regular operating temperatures. Does everything else on the LCD display work ok ? If so it sounds like a defective TEMP sensor
      Argo guy,
      You were right, I replace the sensor and all is ok.
      Thanks for the info.
      Del
