Conquest 8x8 re-build
  • #31
    ok - so I managed to get a new top frame fabricated.
    As the old one was bent to buggery I couldn't take any measurements off it to make the new one - So I had to make one in place on the tub.
    I cut the side pieces a little longer than normal to help with the old girls sag a bit better, Bolted them to the tub, and then went about cutting the cross pieces to fit.
    Once cut, I bolted these to the frame, and using wet rags to protect the tub, tacked everything in place.
    Once it was all tacked, I removed everything and finished welded it.
    All that is left to do is to work out how to secure the fuel tank?? and then finish fixing everything it to the tub and frame
    I've attached some pics of the frame being built, and the bent axle.
    • #32
      Can anyone tell me how the tank is secured?
      from the service manual - it looks like it just uses the tool box on top to hold it in - Is that correct?
      That seems strange to me. I might have to secure it with some giant cable ties.
      I had a bit of a SNAFU with the top frame - and I had to rebuild it... it didn't turn out as nice the second time - but it's structurally sound.
      • #33
        Yup, that is exactly how it is secured on my 2000 Conquest. I took my tray out to clean the top of the tank, its wedged in there tight too.
        • #34
          Cool thanks Dan - I'll not bother with the cable ties then.
          • #35
            Got a little more done this weekend.
            Top frame is finished, painted and bolted in, tank and tool shelf are also in.
            also (not pictured) fuel pump has been cleaned & tested & bolted in.
            • #36
              Until I get my axle parts, I'm now turning my attention to the FD620D Engine and the Tranny.
              While it's out - is there anything I should do besides the obvious?
              I have these things planned:
              clean air filter
              Flush engine with kero.
              Change oil (10W-30 Synthetic)
              Change oil filter (K&N - KN-138)
              Change spark plugs + compression test. (plugs 92070-2072 OR 92070-2112)
              Change gearbox Oil (Nulon Full Synthetic 75W-90)
              Replace throttle linkage (looks bodged up)
              Remove and clean carb
              Replace fuel lines (and filter)
              Change Cam gear from plastic to metal one?
              Change brake fluid (Dot 5)
              brake pads are fine, plenty of meat left on them
              Clean everything!
              Is there anyway I can test the clutch operation with it out of the Argo?
              How much play should there be on the drive belt? coz this one is floppy as buggery. (2"+ play)
              What sort of tests can I do on the Tranny while it's out?
              Is there anything there I should be changing out or checking on it?
              • #37
                Make sure you get the correct spark plugs for the FD620D. I found this while searching for engine information.
                When replacing spark plugs on the Kawasaki FD620D Liquid Cooled OHV Engine,
                it is extremely important to pay strict attention to the specification number of the
                engine being serviced. All Conquest vehicles manufactured prior to vehicle serial
                number CB17857 require spark plug part number 92070-2072. Vehicles produced
                from CB17857 with a specification number of HS12 or later require spark plug
                number 92070-2112.
                Kawasaki has made changes to the Cylinder Heads, Head composition, & spark plugs
                of the FD620D. The newer spark plugs are longer and will cause damage if used in
                an older spec. engine.
                • #38
                  ha ha thanks! - I read the exact same thing!
                  Once I have cleaned it up -I'll be sure to get the exact numbers of it and order the right ones.
                  I may just clean & gap the ones that are in it if the electrodes are not too bad. *shrug*
                  The engine looks dirty - I'm hoping it's only a thick layer of brake dust rather than oil.
                  - but we'll see.
                  • #39
                    I've finally put the parts order in to argoparts.com to get the axles in order, plus a couple of gaskets for the exhaust.
                    (2) Muffler Gasket 620D (11060-2079)
                    (9) Bolt 5/16-18 x 3/8 1/2 Dog (112-03)
                    (8) Bolt 3/8x16x1 Axle Center (112-31)
                    (3) Brg. Flange, 4 blt.clipped (605-63)
                    (2) Outer flange 2 seals (605-97)
                    (1) Bearing Flange (101-20)
                    (1) Slider Block (603-61)
                    (3) Chain Tensioner, Upper Arm (603-77)
                    (3) Chain Tensioner Lower Arm (603-76)
                    (6) Axle Seal CR 12379 (102-15)
                    (6) Axle Seal CR 12361 (102-14)
                    (2) Drain Plug (100-18)
                    (12) Gasket, Outer Bearing Flange, Cork (605-89)
                    (4) Gasket, Bearing extension (605-69)
                    new bearings will come from a local supplier at $19 each.
                    One thing I can't find a part number for is the gasket between the two bearing flanges that hold the inner bearings.
                    I may just have to make these out of an old inner tube or something.
                    • #40
                      I was wondering the same on the inner bearing gaskets. I looked up the part numbers from the Points West Argo online manuals. On the later versions of the Conquest, it looks like they did away with them entirely. I guess you could use a cork gasket if you feel the need for it. I would suggest maybe upgrading to angled grease zergs on some of the inside fittings to make general maintenance easier on you when you put the engine and tranny back in.
                      • #41
                        Looking good
                        As for the gasket between the inner bearing carriers, it used to be a "Card Paper" kind of thing. I don't bother with anything there on mine, but if you think you need gaskets, you could just cut some out of a Beer Box or something like that (Canadian would be my choice )
                        • #42
                          Canadian beer boxes will only work for Argo flange gaskets. Max takes American beer boxes.
                          • #43
                            Jagermeister boxes are universal fit...
                            2010 Chevy Silverado 1500
                            1974 Honda ATC 70
                            1986 Honda ATC 250ES Big Red
                            There is no Z in Diesel!!
                            • #44
                              Ah well, we are working on an Argo here, right. Anyway, I believe that "Canadian" is American owned now
                              Jagermeister...............Blaaa, ..........
                              Have a good night guys
                              Sorry for the highjack, I'll tune out now.
                              • #45
                                Thanks RD - I'll just use a piece of cardboard then - too easy!
                                .. and if i was going to use it....it would be a Wild Turkey box!
