Hi guys,
I am busy with an idea on saving some tyres on my avenger and to make maneuvering a bit easier around my garage and paved driveway at home. I need to move it around a bit into and out of the garage to create more space and the paved driveway seems to chow the tyres. So thought of manufacturing a dolly-wheel / caster wheel using two 10" pneumatic wheels (side by side) which rotate 360 degrees like a caster wheel, and using the Avenger's trailer hitch to mount the wheel when I need it. This wheel will then lift all the wheels about an inch or two form the ground and only run on the front wheels and caster /dolly wheel. I will then be able to actually drive it with the caster wheel. or push it in neutral where I need it, without having it byte into the paved driveway.
Herewith a small schematic on what I'm planning....Do you guys think it will work?
