Does any one have an opinion on the maximum amount of slack in front dive chains is acceptable. The machine I have (Big Foot) does not have tensioners for the front drive chains, and the service / operator manuals are mute of the subject. I would appreciate any ideas or experience in adjusting these chains for tension. Thanks.
Drive Chains Big Foot
It say's in my manual that with the wheels off the ground on the side you are checking and by grabbing the chain between the sprockets at mid point on the top side you should not have more than 2.5" of slack. Hope I explained that well enough.
Do you have a picture. Also check your front bearings to ensure they have not went and are the cause of the problem. If the front bearings are bad they will allow for slack in the front chains. A picture will help to determine slack status.Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
The slack in the front drive chains is 1 3/8 " to 1 1/2", The drive chains are about 12" long, sprocket to sprocket. This seems to me excessive. What do you think? I have included a few photos of the left side chains. Excuse the dirt and grease. Cleanup is in progress. If the front bearing is the problem, how do tell without taking the whole thing apart? Thanks for your replies and input.Attached Files
Originally posted by Mitchell View PostThe slack in the front drive chains is 1 3/8 " to 1 1/2", The drive chains are about 12" long, sprocket to sprocket. This seems to me excessive. What do you think? I have included a few photos of the left side chains. Excuse the dirt and grease. Cleanup is in progress. If the front bearing is the problem, how do tell without taking the whole thing apart? Thanks for your replies and input.
To check the bearings lift the machine on one side where all wheels are off the ground and lift up on tire. If there is movement your bearings are bad and need replacing. Hope this helps.Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
Thanks for the advice. I assume that the bearing extensions in place at the front end do not compromise or complicate the evaluation of the bearings buy lifting the axel (machine is jacked up and all wheels are removed). There is a slight movement when lifting all the axels, and a very noticeable 3/32" lift (at the wheel nuts) in one of the rear axels. The machine has 250 hrs. Should I be concerned? In a new or refurbished condition, is there absolutely no movement in the axels by lifting them?
Regarding the front drive chain, would removing a half or full link be an option in shorting up the chain slop.
