Hi All. Has anyone tackled Idler chain maintenance lately on a BigFoot. I want to remove the idlers and clean them up, but the task of removing them looks daunting with all the tight spaces around the brake calipers and disks. Is there a best way to remove the connecting link clip, which is on the inside of the idler chain jammed up against the brake disk.
For reassembly, the service manual suggest using a modified pair of 7R Vice Grips, with a 1/4" undercut, to hold the ends of the chain together while inserting the connecting link. Has any one made such a tool and used it to reassemble the chains back on to the brake sprockets. I would sincerely appreciate anyone's experience in removing and reattaching the idler chains. Thanks
