Would you be able to send me some photos of your winch kit installation please? I am considering getting one as well and am curious how does it mount.. Thanks
Well it happened. Got the Argo Stuck Tonight
I did not take any pictures but is is pretty strait forward. If you need any help send me a PM with your number and I will call you.Originally posted by zflyboy View PostWould you be able to send me some photos of your winch kit installation please? I am considering getting one as well and am curious how does it mount.. Thanks
The loop will go in through the top engine compartment but before you do any thing you should make sure that your bolts will hand screw into the threaded bolt holes!!!!!!! I chased my holes with a Tap. Put the bolts into the loop on the drivers side first because they are the hardest to get to but leve them loose. The bar is not going to line up with the holes so you want to get the hard to reach side started first then go to the easy side so you can pull the bar open and line up the holes. Once the bar is started I put the inside front plate in place and held it to the front inside with some "dog leg vice grips". I then heated up a screw driver and pushed it through the plastic to mark the holes so I would know where to drill. Once the holes are drilled I removed the clamp and bolted the outside plate to the inside plate and tightened up all of the bolts including the ones that hold the hoop to the frame. I was not impressed with the fit, lack of instructions, or the hardware kit for the price they charge for the kit.
