Can anyone help me out I have a late 70`s early 80`s argo and can not for the life of me figure out how to mount my winch. I can find plenty of pictures and threads on the newer style argos, is the concept the same? Where i am most confused is do I have to tie it to the frame and the body drilling a hole in the plastic does not thrill me at all. Do I need 2 plates top and bottum or just one on tope and how thick should they be any help would be great. I would love to just not put one on but where I will be using it is at my remote fishing cottege which is located in Noelvill Canada its not if I get stuck its when here is what I am working with
Older sytle Argo Winch mount
okay...cant figure out how to put pics in the thread, but if you look in the gallery, under argo 6 and 8 wheelers, mine are in the first page I think.
let me know if you need more specific shots, and I will get them for you. BTW, this (i think) is a factory winch mount, and it does fit and hold up pretty well. The hook under the front winch mount plate bolts through the body.
anyways, hope that helps out
A really simple way from the gallary:
On the page that shows your picture (or any picture you would like to link to), scroll down a bit and copy the text from the box labelled "Linked Thumbnail:" Then paste it.
Like this
If you click the thumbnail it will take you to the gallery page and you can scroll down a bit and see.
The simple way to know if your winch mount is good enough is to think "could I pick the whole machine up and shake it about violently with this mounting". If you have any doubts then it ain't strong enough. Once you've seen a fully loaded winch cable snap or the complete winch tear off the front of the motor you'll never take a chance again.
This is an option I did not think of, Ill call around and see what I can come up with. I would prefer to find something used do to cash flow issue but anything will help. Thanks for the helpOriginally posted by philipatmaxfour View Postleo's all season.....Used to sponsor the Argo ride at the Nelson Ledges in Ohio. May have an old mounting set up in stock. Good luck
Learn to weld maybe ? Not such a daft idea as it sounds as it's a useful thing to know.
