Can you put an Admiarl tranny in a 96 argo
  • #16
    Originally posted by smog View Post
    then you can tweak the governor for a max unloaded rpm of 4000 rpm.
    I have seen a 4000rpm governed engine and it was a lot better than the 3200rpm it had before the tweak.
    Do you have a procedure for this smog?
    I would like to try it on my friends argo. He has the high geared Trans, and something like this might help. Also considered bypassing the governor all togeather, but am unsure about reliability if I were to try it.
    • #17
      The guy just bent the tab holding the governor spring, I will try to take a picture when I see it.
      2008 MAX-IV 500T 30hp Bandolero
      • #18
        I cut each end of my gov spring and bent a loop back in it wow the motor came alive but still has not as much power as I would like in the mud
        • #19
          then do the clutches as per Rock Doctor's instructions
