Can anyone tell me honestly about the new argo frontier 650 hd better than the regular 650 or what and please explain the admiral tranny to me please
New Argo Frontier 650
Both of the transmissions have advantages and disadvantages. When you turn an admiral transmission you slow the inside wheels down 1/3 speed while the outside wheels turn full speed. The advantage here is that you don't have a power loss and you can steer the machine in the mud a keep the drive going to all six wheels (This is a great advantage in bad mud). In low range you can counter rotate which is good for tight turns on trails and certain other conditions.
The bad part about the admiral is the machine doesn't turn as sharp in the woods in high range and the steering will sometimes feel like your not in complete control. The counter rotation is great for certain conditions but it takes a whole lot of power to counter rotate in thick mud and stress's the drive system. The good news is high range works great for almost everything except pulling out stuck machines.
The old style transmission turns sharper but is not as smooth and takes power from the inside wheels and transferes the power to the outside wheels. The good thing about the old system is you can get the lower 3.3 transmission which is low enough to pull stumps if you want to.
If I were going to run the machines on stock 24" tires I would take the Adimral every time. If I was going to run a set of Adair tracks I would take the old style transmission because the tracks make up for any disadvantage in the mud and the low transmission is simple and reliable. The old style transmission is also easier to control in water.
So there you have it-consider where and under what conditions you are driving and how the machine will be used
Ok, i just recently(October 2011) bought the 2011 Avenger with the Admiral transmission. Things i noticed that was different.
If you start off from a stand still with the steering turned to it's max in either direction in does not turn as sharp as the 06 Avenger that i had, but if you let the transmission do the work like it is designed to do. Now this is what my unit does. Let the machine move forward and it feels like Power steering and turns almost as well as the 06 as far as the turning radius from the stopped position. Keeping the machine transmission in a rolling state and the transmission will do the work. I used the low range only once to test it out. Other than that I did not need it.
On the trails the transmission which i mostly run in high gear had no problems turning, again it felt like power steering, Note: Very easy to change direction or over correct with one or two people. At the last Busco ride i had at least 4 people most of the time and at other times i had 5. Steering still felt like power steering with no loss of power. The 31HP fuel injection is quiet a jump up in power from the 26 carb and i think it really helps the machine perform at a higher level.
As with any 8 wheeler vs 6 wheeler the trails are easier for the 6, but this is a lot due to the fact that the 8 is longer and some times you have to back up and re-adjust to make the turn due to length not turning ability. I had no problems navigating the tight trails at Busco, if the machine would fit through it, it would go. We all seem to get to the same destination and that is what matters.
This is how my machine performs and i hope this helps. I drove the 06 for 5 years and instantly I could tell a difference. Even on pavement it turns easily.
Now with that said, i am far from any guru on this new machine and i am still in the learning process but i am quiet satisfied with it's performance. If it holds up as well as the 06 Avenger i will be super happy.
I have had a 03 Conquest, Great machine…….06 Avenger, Great machine and now the 2011 Avenger looking to be equally as good……each time I traded I have had to learn what made each one tick all over again.
No but it is one of the major items. The axle bearings and housing carriers are much more robust and the axle hubs are larger.Originally posted by swamp donkey View PostLewis is the transmission the only major difference between the 06 and the 2011?
There are more difference but mostly cosmetic. Dash, digital read out, hydraulic hand breaks, thicker seat cushion, quieter engine, neutral switch, headlight to body attachments, hand break(not a great location), heavy duty floor pans. No Jackshafts. The 11's have a telescoping shaft that attaches to the trans to take the place of the jackshaft. The tires are the AT 189.Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
lewis, As you know the'' more robust' axle hubs have a single grease nipple that you can grease without removing the wheel or the tracks if you have them on. That alone would be worth more to me on my 2007 Avenger than all of the fancy speedometers and guages but I could use the parking brake. Congrats on your new one.
Yes, and thanks. You are correct, forgot to mention that point. Since there are no lip seals the second grease point is not needed. This is a mod that can be done to your 07, i had though about doing it to the 06. The park brake takes a little getting adjusted to. Being that i am only 5'10'' , Never pull the park break up prior to trying to exit the driver side. I generally get out of the machine first then set the brake. One exit and you will understand.Originally posted by philipatmaxfour View Postlewis, As you know the'' more robust' axle hubs have a single grease nipple that you can grease without removing the wheel or the tracks if you have them on. That alone would be worth more to me on my 2007 Avenger than all of the fancy speedometers and guages but I could use the parking brake. Congrats on your new one.
Here is the difference in bearings and axles.
As you can see there is not much difference appearance wise except the hood scoop between the 06 and 11.Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
Lewis,Originally posted by philipatmaxfour View Postlewis, As you know the'' more robust' axle hubs have a single grease nipple that you can grease without removing the wheel or the tracks if you have them on. That alone would be worth more to me on my 2007 Avenger than all of the fancy speedometers and guages but I could use the parking brake. Congrats on your new one.
Is greasing the bearings through the Hub as much of a PITA as I've been told? I've never done it, but have been told several times that it's not as easy as it sounds, as far as getting the hole to line up with the grease nipple, finding or having to make a long/ridged outlet line for a grease gun to reach the nipple (One guy told me he slides a piece of tubing on the "flex line" of his gun), not being able to tell if the grease is getting in or bleeding out around the fitting and the nipple, ect. I can't believe it's that big of a deal, but.............
I was going to drill the hubs on my Conquest to grease my bearings (I have upgradedd to the HD bearing assemblies), but was talked out of it.
