We have an older argo, 86 we think, 6 wheeler we are using to sugar in northern VT. We recently had the rings done on the old 16 hp tecumseh engine. Everything was put back in and it runs well for a tecumseh, our problem now is that the battery runs dead after a few uses. We disconnected the lights to save on juice. All that the bat. runs is the fuel pump and starter at start up. Brand new battery as that was our first replacement. Is there a good way to test the stator? I was told by the person that overhauled the engine that the engine would not have started for him on the lift after he did the rings if the stators were bad, does that sound right? We are not the best at electrical work but we can turn a wrech. Also the fuel pump looks to be an add on. Why would this be necessary? I assume these machines did not need fuel pumps at manufacture time. Thanks
argo charging system
You need to check the battery voltage when it's not running and then start it,turn on the lights and check it while it's running...should be more volts when running.
You could have something draining the battery when it's not running.
Remove the ground wire on the battery and see if you get any spark when you touch it on the post. If it sparks something is using power.
A battery shut off switch will solve that problem.
Fuel pump is needed to supply fuel to the engine.
Gravity only works if the tank is higher than the carb and you are always on level ground.
Pilot are you saying you have an electric fuel pump? Tecumseh's were very common for bad fuel pumps because they were way over engineered and mated directly to the carb so maybe someone divorced your pump from the carb and is now using an e pump? if so most aftermarket pumps do use too much power even more so when they put a regulator on it'99 Conquest 104hp turbocharged intercooled EFI Chevy Sprint conversion
"Argo 8x8's only" type of guy
"old school Argo expert
Thanks for the info. It is an after market electric fuel pump. In fact we put in a new on with less pounds than the nor that was on it after it quit. I assumed that the stator should be more than able to keep the battery charged. I do not think that there is something draining the battery when it is not running because we have left it for day's and not had a problem starting it. It quits while it is being run around gathering etc. we tend not to run it at high throttle low gear etc. a volt meter should show me where the problem is I was told I could bypass the charging system with an alternator. I am finding that these older Argos seem to have one problem after another although my dad at 67 says it is as close to his old tracster as he could find. The tracks are the ticket!
I agree totally, if you have 12 volts or greater (14 is nice) of current while the rig is running between the battery terminals, it is working. If not, people have them on here. I think almost every argo needs an alternator, I just haven't figured out where to put mine yet.
I went up this weekend. Did not get around to testing the stator. Had an interesting time with the Argo. Jumped in the rig started up broke our trails for gathering rode for 20 min. Stalled it at one point and the battery would not turn over the starter. Hooked up the vector started the rig ran it all over but as soon as we shut it down would not turn over the starter. Had enough juice to run the fuel pump but not enough to crank the starter.may just be that the starter requires a lot of juice not sure. Wish it had a true recoil back-up. Still think I have a charging issue bad ground ect. Hopefully we can get through sugaring.
You need to verify that it is charging #1, You could have a bad starter if the unit IS charging, it may be pulling too much current for it to start unless your battery is at 100%
First thing is to verify that you are charging though.09' ARGO Avenger 750 EFI
With near every option Argo makes
and a few they don't
