How many of you are like me, grease your bearings almost after every use.
Well this is what I have found.
INNER BEARINGS I used to bend over the side and pump a little grease into the bearing until I saw a little bit of new grease coming out the side.
{Well} I could be greasing all day and still not get any grease into the bearing.
As we all know the inner bearing is between an inner flange and outer greaseabo flange. The bearing has a hole in it to allow the grease into the bearing.
IT,S A GREAT IDEA ON PAPER.
But As we all know the grease takes the path of least resistance So if the flange is bent even a little bit could be from fatigue or ware. The grease will not enter the bearing.
All you will be doing is greasing the outer race and flange.
To check this on your bearings. Clean off the flanges and pump a little grease in. If the grease comes out between the flange and outer race. You can grease all day if you want and not get any grease into the bearing.
When the dealer hits you with a big bill to change your bearings and tells you it because of lack of maintenance. He is right. You have been greasing the flange and outer race, Not the bearing.
All in all, the flanges are to thin and bend to ease to per vide proper support for the bearing.
The only way to grease the bearing is to remove it from the flanges and grease it with a needle. BIG PAIN IN THE ASS IF YOU ASK ME.
I take it That is way they like to sell you bearings and say it just lack of maintenance. In stead of having a recall on a bad flange designed.
The outer bearings are a little better because of the solid cast bearing support
2002 conquest.
{Well} I could be greasing all day and still not get any grease into the bearing. As we all know the inner bearing is between an inner flange and outer greaseabo flange. The bearing has a hole in it to allow the grease into the bearing.
2002 conquest.
