Argo parts website
  • Argo parts website
    Hi all,
    Just wondering if there is a site to buy argo parts such as berings, seals or anything you might need to keep your Argo in tip top shape. I am really looking for a site that may have part descriptions and the prices 4 the parts you are buying. it seems that I have to find a dealer, tell them what I want, then they call argo find a price call me back..... Seems to take forever. I just want a good ol fashion site that I can see the price of the item I am I am buying. any help would be great.. oh yeah I am still wondering if the conquest outer bearings are the same 72mm by 1 1/4 as the max bearings are. I'm just wondering this because I can get it right at tractor supply. Are the inners and outters the same size ???
    I did a search and found a place on the net that has new parts.....I do not know if this is breaking the forumn rules and if so sorry Mike....you can remove this tread if it is (someone let me know)...google argo parts manual library.....this site has a search engine that you can use and gives a price list.....it also has parts manuals for different machines.....it is best to search with the part number from the parts manual
    I should mention that I can get things cheaper from my local argo dealer then are listed on this site....Site is in US and I am in Newfoundland Canada.....
    —Will Rogers
      The inner and outer bearings on a conquest are different. Outer bearings are part# 101-35 ( 1.25 ) and the inner bearings are part# number 101-41 ( 1.0 )
        Please look at all the links before you decide on where to do buisness with.
        BuyArgo.com is America's Argo ATV Super Store - Grand Junction, Colorado Reasonable prices, Great place to research the expanded diagram of parts.
        Adair Argo Sales Good prices, (but not alot of diagrams. Good prices)
        Snowmobile Parts, Go Kart Parts, Lawnmower Parts, ATV Parts, and more | MFG Supply Best prices but hard to find "argo parts"
        good luck!!!
        In my experience it is best to make friedns with your local argo dealer
        ATV = Alaska Terain Vehicle
          I have had a good experience with points west Argo who run argoparts.com
          Very helpful, and also shipped to Australia no problem.
          They have a full online catalog with pics of most parts.
          HTH
          Cheers
          Mitch.
            You can get bearings to fit a Conquest from Buffalo Bearings 1-800-669-8019. The outer bearing and idler shaft bearings are argo part number 101-35, which is the same as a UC206-20. The inner bearing argo part number 101-41 which is the same as a UCX05-16. I would suggest getting the outer bearings with triple lip seal, code R3.
              Is this the bearing for the above mentioned ucx05-16?
              the wholesale-to-the-public bearing discount outlet, that carries radial ball bearings, insert bearings, cast-iron and stainless steel mount units, including, pillow block, 2-bolt, 3-bolt, 4-bolt, flanges.
              Thank you.
                When I checked Motion Industries, Adair Argo was cheaper. In the case of the HDI outer bearings, they were half price of MI and in stock also. MI had to order them from Canada.
                And apparently Timken is buying up all the other bearing mfgrs.....I'd expect bearings to go up in the future.
                  hi
                  Remember that a outer bearing needs to be submersable in water eg triple lip type
                  3x lip is more expensive than a 2x lip seal up to double
                  An inner bearing typically a 2x lip seal ,only tolerates water splash
                  There is a lot more drag on a triple lip bearing
                  tomo
                    Originally posted by Tomo View Post
                    hi
                    tomo
                    The "older" style bearing is used with a separate outer seal on the retaining flange. The "new" style HDI bearing is fully sealed and doesn't need a separate seal.
                    The HDI bearing is also the larger 72mm, and the old style is smaller at 62mm outside diameter.
                      1" Insert Bearings UC205-16
                      Thank you.
                      No.The link posted is for a UC205-16 it has a 52mm OD.Argo inner brg's are 62mmOD,they are bastard size and hard to find in the triple seal denomination (other than thru Argo).That's why they are designated UC"X"05-16 not UC"2"05-16. The -16 is correct for 1" ID but must have a 62mmOD. Look at the dim's in the link.
                      Joe.
                      Last edited by JoeMeg; 10-16-2012, 07:59 PM. Reason: added the triple seal clarification
                        Thank you.
                        This seems like the correct one.
                        UCX05-16 1" Insert Bearing (Medium Duty), Set Screw Locking
                          Thank you.
                          Yes,those are the correct size inner axle brg's for your Argo. It doesn't specify the type of seal with a suffix of say,R3 or LLJ, but as Tomo mentioned earlier in this thread,the inner brg's do not have to (or at least shouldn't have to) deal with submersion.
                          Joe.
