I have a 18hp kohler magnum. I have to drive in low range most of the time, the motor doesn't have the power to drive in high range. I goes but very slow and it won't turn, it just stop if I try to turn. I checked my brake and they are not stuck on or anything. My secondary clutch is new and work good as well as the primary and I have a new belt. In neutral I rev the motor but it take time to get some rpm(my weedwacker have more pep than that). I play with the carburetor setting and only seen a slight improvement. I need some advice
Argo Magnum lost power!!! HELP!!!
check into the manuals section on magnums. THe manuals should have factory settings on them, and a trouble shooting section. Easy peasy. If you cant find them Just message me, or yell for help again!Alaska floating atvs group on face book. Fixing help and trail rides!!!!!
ATV = Alaska Terain Vehicle
Check to make sure you are getting a sufficient fuel supply to the carb. Pull the hose off at the carb and crank it over, be sure to catch the gas in a can and observe the flow. If it is weak check the fuel filter or replace it. If the filter is clear or has been replaced then the fuel pump may be suspect. Of course, what Mike recomended by pulling the choke out a little you would be enriching an otherwise lean fuel condition if the filter was plugged or have a bad fuel pump. You might also do a compression test to see that both cylinders have equal pressure. Happy hunting... RR
Okay so there is either a keeper dropped off one of the valves or you have a blown head gasket. It is likely the keeper, a blown gasket might still make a little pressure in the cylinder. Follow the breather tube to the crankcase valves on the block and remove them, this is where the valve springs live. If the keepers are intact it may also be a stuck valve. I dont remember if the breathers are on the top or on the sides of the cylinders, hope they are on top. Good luck!!
Blowed head gasket. At least one inch of the gasket was missing. Replace gasket from another good motor I pick up for $50 this weekend. Got 100 psi in both cylinder now. Seem a little low to me but motor is working awesome with great torque.
I drove it for about 2 days, blow the same head gasket again. Replace it again but this time took the other spare head I had on my spare engine. Will see if it will last or not. My original head might been warped. Or maybe I should use a new head gasket.Last edited by ianferron; 05-22-2012, 06:24 AM.
