Hi, i would like to know how many section of 18" track i need to install on a 1985 Argo 6x6 Vanguard with 20-11-8 runhamuk tires???
I just remove 13" track with 27 link+1 halft link and they almost rub the wheelhouse and needed 7-8 pd of air to keep the tire from spinning in the track... I install the 18" with 28 link +1 halft link and i got the same problem... With the Argo in the air tracks are looking loose (6 " travel from tire) Did I need to remove the six tire valves, suck the air out and put 27 link...??
Here we got a lot of snow... 8-9 ft in the front of the house, 4-5 ft in the back and 3-4 ft in the trails... That's why i need 18"... I tried them tonight and it was a challenge....
Next time i"ll bring the head cam to show you....
Martin
buried in the snow, Québec, Canada
Ps: I just look the hole forum pages on Whipper Yellow Springer and i also congratulate you for that masterpiece suspension
You really did a great job... By the way, in a part of your testing, if you want to try it in the snow call me
Next time i"ll bring the head cam to show you.... Martin
SRG121, thanks for the tip, i will try yo removed the half link first and maybe more if needed (remove a section and put back the half link). I hope I'll do the trick!!!!
