gas smell
  • gas smell
    Good morning guys! I was just wanting to know ifs its common to smell like gas after a ride? The Argo runs perfect aside from having to give the throttle a little blip to idol down in order to change gears. I also might add I use an enclosure.
    Much thanks!
    Much thanks!
    No not normal at all,you are going to have too provide more info on the machine ie:model,year,six or eight.NCT
      Thanks NCT! I think I know why...stupid me sat and let the Argo warm up, and even although had the door opened all I could smell is gas smell which I hate! The next time I'll push it outside and then start it!!! By the way it has a 17hp kohler which runs like a top!
      Thanks again NCT for the quick reply!!!
        Well Iam not sure whether you meant Exhaust smell or gasoline odor,any more problems be more specific we can help.NCT
          Much thanks!
          Your machine should have a vented tank, so in warmer weather you would get a gas smell in your enclosure, I believe.
          Bumping the throttle to idle down is a common thing, I do that with both of my Conquests too.
            Thanks RD that's good to know, and probably a stupid question, but how do I know it is a vented tank. I think it was exhaust but??? I haven't had it out since yesterday, The wife said she could smell a little, but not much. When we finished our ride, which was a good hr+ she didn't smell like gas...me on the other hand did. That's why I think it was sitting in it while it warmed up?
            Thanks for the reply
              Maybe I worded that a little strange, what I mean is that it IS a vented tank, if it wasn't, you would draw a vaccum in the tank and your engine would eventually starve for gas and stall. I wonder how a gas smell could stick with you for that long if you were just in an area with a little vapor. Sounds like you fueled up and spilled some on your hands/shoes, ect, or something like that. I'm not one to judge though, I probably smell like gas most of the time
              Some machines just have a vented gas cap, others have a tubing line from the gas fill line run through the body to tha back of the machine
                Did you consider the location of your exhaust????? Are you riding with a canopy???? When I got my 02 conquest the person before me modified the exhaust and I was getting fumes back inside the canopy. I put the exhaust back to the orginal way and no longer have that smell.
                —Will Rogers
                  I went out tonight and just checked it out and I can just smell a whiff now and then. I believe its because its an older model. I was wondering if I could get a new cap, one like on a 4 wheeler gas tank?? Its so little like I said, my wife could hardly smell anything! I think I'm just a little over sensitive?
                  Thanks again guys!
