I cant be the first to do this, and i know i wont be the last. Pleas bear with me as i explain myself.
Hello all! With this thread i hope to explain my method for extending the inner frame rails in my argo. My old argo, a 84 I/C used long front axle. Problem is, that if i ever brake one, or bend one (one IS bent), i cant order new ones, there kind of non existent. Insteds im going to replace it with the The short HDi argo axel shafts. You dont have to run HDI axle shafts of course, you can use normal 6 spline argo axles too.
I didnt get good pictures, but i removed the old steel plate that was welded to the frame, just in the engine compartment. I am going to replace it with a FULL LENGTH peice that goes all the way down the frame. That should make it way stronger.
The frame:
The front of the frame. Nottice the old chunck of 12 Ga laying on the ground. Flipping the frame over i was able to get most of the welds. The 6 welds betwene the two existing frame rails were a MOTHER to get to. I just used a prick punch on either side of the welds and then drilled through so i could flip the frame over and have orinitation for cutting the welds. sorry i forgot to take a picture.
Have a peice of 10 gauge (or 12 gauge would be fine) formed into a frame rail, 20 inches long, 4 and 1/8 out side. Should look like channel, 4 1/8 by 1". I cut mine so the bottom is flush to the bottom of the existing frame and leaving an "ear" to weld onto existing frame. Flush to the bottom of the frame and clamp tightly. (I used a pair of vice grips to hold a strait edge on the bottom of the frame.. way easier than guess and check)
Use a 3/8 SHORT high speed bit to punch out the holes (after yo u get the holes use a 25/64 regular bit to punch them out)
Need a notch for the jack shaft to fit in. (going to do this a different way... stay tuned)
Million different ways to find a center point for cutting the hole with a 2 3/4 inch carbide hole saw (tried Milwaukee metal/wood saw that was a FAIL!!) AKbuff truck just made me a jig, but you could scribe the center with lines either with a strait edge or compass, either way find the center of the four holes and get a 1/4 inch hole.
voila!
Cutter Of doom... 80 bucks carbide steel cutter I think if your just going to cut 2 holes, a Milwaukee plain hole saw would work for just two (i cut a total of 18 holes so i stepped up on the big one. If your in Fairbanks AK PM me and you can borrow it)
looking kind of holey!
Please post up your cheers and jeers.. spelling questions, more pics of how you have done it or what ever. All input is welcome and appreciated. I especially love questions.... it all makes sense to me but clarification for you will help others too!
The frame:
voila!
