Here are some pic's.
Cut these "splices" from aprox. 1/8" thick ABS. Took the bottom one and buttered it up with some thick goo,then placed it on the crack that I glassed over previously. Then I glassed over the splice.
Soaked the T shaped pc in a jar of thick goo for about 16 hours,it was very workable. Waited a little more than two weeks before glassing over this and a similarly repaired corner.
Took care of the muffler opening also.
In preperation for the cold snap in the forecast I took the "MI" T-20 off of the cradle,or vice versa
and brought it to the basement workbench. But not without first draining it. So,Jim,as promised I will do this one first. I got about 1/2 to 2/3 qt. of fluid out of it. The fluid was thin and free flowing even at about 35 -40 deg. it had a reddish/brownish color to it. No unusual odors,metal shavings or anything else in it. The shifters are free and move smoothly. They are not at all sloppy in their bores. When drawn snug,all four plungers protrude aprox. 1/4 to 5/16" out of the case. So,as of now it looks optimistic. Will most likely tear it down tue or wed evening.
Joe.
and brought it to the basement workbench. But not without first draining it. So,Jim,as promised I will do this one first. I got about 1/2 to 2/3 qt. of fluid out of it. The fluid was thin and free flowing even at about 35 -40 deg. it had a reddish/brownish color to it. No unusual odors,metal shavings or anything else in it. The shifters are free and move smoothly. They are not at all sloppy in their bores. When drawn snug,all four plungers protrude aprox. 1/4 to 5/16" out of the case. So,as of now it looks optimistic. Will most likely tear it down tue or wed evening.Joe.
