If anyone has an Attex Tomahawk or Tomahawk 'Lil Truck (with the OH160 Tecumseh, of course) I have some part numbers for the correct replacement drive belt..............after over an hour of searching!
Here's what I found. The original belt (which was never changed on my Tomahawk Lil Truck) is a Gates 6086, which is 44-5/8" long by 1-3/16" wide. They don't make that one anymore so I came up empty handed. But after some digging I found this excellent Goodyear belt catalog with a lot of AATVs listed in it. I got the part number, which is current and did some cross referencing and also found what snowmobiles used this size as well. I found all these part numbers for belts from different manufacturers that will fit an Attex powered by a Tecumseh and posted them below.
-Goodyear 71148
-Parts Unlimited LMX1116
-Dayco Max 1116
-Dayco HP3029 (this one replaces the Max 1116)
These belts are all a pretty much perfect replacement, measuring in at 44-9/16" long by 1-3/16" wide. They're only a 1/16" of an inch shorter than the stock one, but that won't make really any difference at all. They're also very easy to find online like ebay, or at your local parts store. But if someone looks at you weird when you say you need a belt for your Attex Tomahawk, here's a list of snowmobiles that uses this belt with the same exact specifications:
1992 Polaris Indy Lite Deluxe
1993 Polaris Indy Sport 440
1992 Polaris Indy Sport 440
1991 Polaris Indy Sport 440
1992 Polaris Indy Sport GT 440
1991 Polaris Indy Sport GT 440
And here's the Goodyear belt catalog with many AATVs listed in it:
http://www.goodyearrubberproducts.co...nt%20Belts.pdf
-Goodyear 71148
-Dayco Max 1116
