When I took the body apart there where staples holding it together, sort of along with that rubber gasket\bumper. Any ideas how to join the upper and lower tubs? I'd like to use the staples just not sure what size staple and what kind of gun you would need.
How to attach top tub to bottom tub?
I am planning on building a body band for my Attex and using bolts and some abs goo to hold the 2 halfs together. I've saw some photos on here of members using rivets to hold the 2 halfs together. Don't know about the staples tho I'd be interested in finding out my self.Courage Invites Critics
The combination of goo and pop rivets is the best way to do it.Originally posted by amphibious drew View PostWhen I did my colt racer, I used a bit of goo, drilled holes and put rivets in them, and then I mounted my roll cage/belly band with bolts."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
